Heat Pump with additional radiant baseboard heat
Our house has a lennox heat pump/air conditioner and an oil radiant baseboard heat. Right now I have 2 thermostats and I manually turn on the radiant heat around 25 degrees and turn off the heat pump. I bought a Honeywell VisionPro 8000 with wifi with the intention of having the thermostat automatically switch between the two. I have the heat pump hooked up and the outside temperature sensor. I would like to ad the oil furnace to the thermostat but I am not sure how since its a separate unit. It seems like I should hook it up on the U1 terminal as a Stage 2 heat but I am not certain. Any advice?
