air handler Trane TEM6
Old 03-04-17, 06:19 PM
My new air handler and HP will arrive in 3 weeks. I need to get the branch circuit wire install. I'M told it takes 2, 2pole breaker. It is a 20kw unit, 83.33 amps. I know that means I can run two #6 cables (cu) but I know I also could run One # 4 (cu) and splice in the # 6 at the air handler to the disconnects on the air handler. I could also go with #2 Al. but need to splice to #6 copper at the air handler. What I don't know is what is the voltage of the motors in the air handler and do I need a neutral in my circuit?
I don't have a wiring diagram or the air handler to look at.
Thanks
Old 03-04-17, 06:23 PM
Received 1,204 Votes on 1,114 Posts
You can only connect copper into the unit.
I usually run what they specify. If the unit has two breakers..... run two circuits.
The blower will be powered from one of those two circuits.
A neutral is rarely needed.
You will also need a 240v 30A circuit for the condensor...... typically.
Old 03-04-17, 06:37 PM
I was just looking at the Trane specs. I'm not seeing a 20K heating unit.
