Replacing Heat Pump Thermostat
Old 04-26-17, 05:31 PM
H
I am replacing my heat pump thermostat but bought an Orbit Thermostat - I have an E wire and a blue wire that the new thermostat can not accommodate - I realized after the fact I have a heat pump thermostat. If I leave the E wire off will it hurt anything? or do I need to replace it with a compatible thermostat.
My old thermostat was a Bryant Heat Pump Thermostat - the replacement is an Orbitz Clear Comfort Pro - Can I use the Orbitz if it does not have a place for the E wire?
The Brant had:
C - Blue
W2 - White
R - Red
G - Green
O - Orange
Y - Yellow
E - Black
Orbitz
G
O/B
Y
W
RC
R
Old 04-26-17, 05:36 PM
Received 4,082 Upvotes on 3,665 Posts
Welcome to the forums.
I'm not familiar with an orbitz thermostat. You could post the model number.
You need a heat pump thermostat with back up electric heat.
Old 04-26-17, 05:50 PM
H
This is the exact thermostat - specs are on this page below
https://www.lowes.com/pd/Orbit-Clear...stat/999958143
It was already hooked up without the E wire connected. Is it possible to leave the E wire off?
Old 04-26-17, 06:01 PM
Can you use it that way..... yes.
You will not have any back up electric heat or emergency heat.
I'm curious why you choose that thermostat.
Old 04-26-17, 06:53 PM
H
i only chose it cause i had no idea my parents had heat pump thermostat otherwise I would of just bought a compatible one. I just thought I needed a digital thermostat and that one looked "nice" so I bought it.
I just found a little jumper wire in the Orbitz parts and it says "For heat pump only install between Y and W"
if it will work where does the E wire go?
I notice on the stats on lowes it says:
Compatible with Heat Pump (No Aux.) Yes
Compatible with Heat Pump (No EM) Yes
Compatible with Heat Pump (With Aux.)No
Compatible with Heat Pump (With EM) No
Old 04-26-17, 06:57 PM
H
Is honeywell a better one because I noticed it has a place for the E wire?
Old 04-26-17, 07:28 PM
You put the answer in your post.
This is your system. You have aux/em heat.
It will work but not activate the electric heat.
You would need that jumper to use that stat.
The Honeywell sounds like it will work better.
