Heat pump thermostat problems
I had what I thought was a simple thermostat installation and have the following problem. Lost 24Vac between the common and red wires/terminals. This is a heat pump with 7 wires with the following terminal - wire list:
G - Green, Y - Yellow, E - Blue, W2 - White, C - Brown, O - Orange, R - Red.
After I connected everything to the new Honeywell terminals and plugged the thermostat; the screen was blank. I called customer service and they said probably not enough voltage to power the new thermostat. I checked voltage between the Common -C and red wire to find no voltage. I reinstalled old thermostat exactly as removed (I have a photo of original) and as expected it doesn't work now because there is no power between C an red terminals. My heat pump is an old Day an Night unit made by carrier. What can be the cause and anything I can do before calling for service?
Check the fuse on the control board in the furnace. If you didn't shut off the power to the furnace you probably shorted the wires.
Welcome to the forums.
We haven't heard back from the OP in a while so maybe he figured out the problem.
Since he has a heat pump he's not likely to have an actual control board like a furnace would have. He could possibly have a fuse but more likely the transformer has been shorted and is fried.
