Making heat pump emergency heat only
Old 10-29-17, 09:42 AM
G
I just installed 2 new mini split units to replace my old heat pump that uses duct work. What I want to do is use the electric emergency heat as backup.
My Question --I would like to remove the outside unit. If I just cap off the wires going to the outside unit and keep the inside wiring the same, and set the stat on emergency heat will this work.
Thanks
Old 10-29-17, 10:02 AM
Received 3,593 Upvotes on 3,222 Posts
Welcome to the forums.
Yes... that will work. You would keep the stat in OFF when not in use.
Old 10-29-17, 11:18 AM
G
That's great. Thanks for the welcome and the reply
