Defrost stat
Old 02-14-18, 08:38 AM
T
Received 3 Upvotes on 3 Posts
Defrost stat
Where can I get the defrost stat to my goodman Aph1536m41ab. model heat pump package unit ?
Seems many sites are sold out so this must be a common problem on these.
Can it interchange on part# also?
Thank you
Old 02-14-18, 11:14 AM
Received 3,973 Upvotes on 3,566 Posts
Part # 0130M00009P Alternate part # 0130M00102
Defrost Thermostat: Open 60f - Close 34f
Goodman-0130M00102-Defrost-T-Stat-0130M00009P
Ebarnett/goodman-defrost-thermostat-open-60-deg-close-34-deg
Appliance Part # 0130M00009P
Old 02-14-18, 11:34 AM
T
Thanks!
Do the open /close tempts matter ?
I'm in Tn.
Saw one that was 62 / 25 also..
Is it better to go w the 60/32 ?
Old 02-14-18, 12:03 PM
I was just looking at the part your unit called for. Close at 25f may be too low.
Old 02-16-18, 03:04 PM
T
Ok
I guess I'll go with the higher degree one you shared
Thanks .
