Drain Mitsubishi mini split exchange unit
Got leaking drain. leaks into wall and down into garage.
Anyone knows how to get to it on Mitsubishi ductless exchange unit? It was working fine for almost two years, either slipped off the nipple of somehow got plugged.
I just need to know how to get to it.
Thank you.
Thank you.
It's in the bottom corner, can be on either side, depends how guy installed it. Drain is supposed to be tied into refrigerant line, taped together, so it will be cute to get to just the drain line. I'll have to figure out how to remove cover to get to it. Likely clips, it's Japan.
More than likely it will require two people to do. You'll need to lift the unit up and off the wall hanging bracket very carefully so as not to damage the refrigerant lines..
From what I remember..... the line is connected to the back as the unit is installed.
It should be illustrated in the installation manual. If you don't have it.... post the model.
I know where the drain is. It's getting to it didn't.
Bless his heart:
https://www.youtube.com/watch?v=texGW7Gi3fg
Bless his heart:
