Please help: 8-wire thermostat wiring
Old 11-04-18, 07:27 AM
D
I'm replacing an old mercury switch thermostat with a programmable Hunter off-the-shelf unit, model 44133. However, I've gotten twisted up over matching the new unit's terminals with the existing one's wires. Here's what I'm looking at:
(See diagram at https://flic.kr/p/QvTBLh)
OLD UNIT TERMINALS (wire color):
R (red) - G (green) - W1 (yellow) - X (brown) - E (blue) - W2 (white) - C (orange) - Y1 (black)
NEW TERMINALS:
Rh (jumped to Rc) - Y - G - W - (blank) - O - B - W2 - Y2 - (blank) - A
Can anyone help me match old terminals to new? Thanks for any help you can offer!!
Old 11-04-18, 09:06 AM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
I don't usually comment on a company's product but when I can't find proper installation support directly from that company.... I do not recommend it.
I cannot find a wiring diagram for that stat. I can't even find any information if it will even work with a heat pump system with back up electric heat.
As I look further..... I don't think you have a heat pump. What is your system.... exactly.
Old 11-04-18, 02:08 PM
D
Thanks for the reply, Pete. Yes, frustrating...I looked online as well and could only locate programming instructions; no installation guide.
I'm working with a Gibson heat pump:
Air handler model is GB3BM-024K-AB
Outdoor unit is model is GT3BA-024KA
If you have any recommendations for a compatible off-the-shelf programmable thermostat, I'd be most grateful.
Thanks for your assistance!
Old 11-04-18, 04:08 PM
Ok..... you have a heat pump. Do you also have backup electric heat strips ? (not gas furnace backup)
Old 11-04-18, 04:46 PM
D
Yes...all electric; no gas.
Old 11-05-18, 07:01 AM
R
Received 103 Votes on 97 Posts
I couldn’t find much on that thermostat.
Just a quick question, you bought a programmable thermostat. Do you plan on setting a schedule to use occupied/unoccupied setpoints?
Old 11-05-18, 11:46 AM
D
Yes, basically. It's a unit that handles the upstairs of the house where the bedrooms are located. Wanting to do setpoints to back-off usage during unoccupied periods.
Old 11-05-18, 11:49 AM
D
Update: I had a tech visit and examine the situation today. Discovered that the installer from 15+ years ago did a FUBAR job of wiring the unit. Tech says he recommends rewiring the entire low-voltage side prior to installing a new thermo.
Old 11-05-18, 12:04 PM
I would say that sounds about normal. Since we aren't there and can't see it.... you'll need to go by his advice.
Old 11-05-18, 12:12 PM
R
Unless that thermostat can lock out auxiliary heat, either return it or don’t use the programmable part of the thermostat.
Your heat pump will use more energy recovering to occupied setpoint then it would have maintaining a consistent setpoint.
Premium programmable thermostats can lockmout auxiliary heat during temperature recovery, and can actually save energy.
Old 11-05-18, 12:26 PM
Excellent point..... and something I neglected to mention.
Any savings using a setback thermostat can be lost if the electric reheats are turned on.
