Heat pump is froze inside and out
Carrier heat pump,about 10yrs old not sure of size ( maybe about 5 ton ) . I in eastern Canada . I would appreciate any info. tks. John
Welcome to the forums.
Are you saying the outside condenser iced up and the inside coil was also iced up ?
The first thing that would need to be checked is the refrigerant/charge level.
If the outdoor unit is frozen you likely have a defrost issue.
Is the indoor coil frozen as well?
