Quietwarmth radiant floor heating question
Old 12-27-23, 09:11 AM
C
Any suggestion to why our floor in zone 2 stays on heat? We have the sensor in zone 1 connected to a thermostat and from there to TH-power module for zone 2. Zone 1 operates as normal, but zone 2 stays on heat. It is the 240 volt system and the square footage is below 300.
Old 12-27-23, 01:06 PM
Received 4,055 Upvotes on 3,638 Posts
I'm not following.
Do you have the room split up into two zones with two thermostats ?
Old 12-27-23, 06:30 PM
C
It is split into two zones, but with one thermostat. One zone has the sensor which is connected to the thermostat. The other zone is connected to a Quietwarmth power module TH-Power. It is the same as the Schluter Ditra E RR Power Module. That module is then connected to the thermostat which controls both zones
