Pool timer switch contacts
Received 0 Votes
I have an intermatic pool timer switch the quit working. I opened it and the on off contacts were pretty burned. I filed the contact pads but not sure how long that will last and I need this to work for a couple more days.
Is there a way to reduce the voltage to the contacts by putting a resistor in series?
Any ideas on how I can get them to work again for a few days is greatly appreciated.
Also so how do I get a picture in here when using my phone? I only see a link but no way to chose a picture that is saved on my phone?
Thanks in advance
Thanks in advance
Not much you can do with the contacts. The contact arms get weak from age and heat and don't have the strength to close tightly. You can clean the contacts and bend the arms tighter but it's strictly on a limited life basis.
I only load pictures from a laptop. This is the link I use. Not sure if it's applicable to a phone.
How-to-insert-pictures
I have never found a plug in timer to handle anywhere near its claimed "rated" switching limit reliably. Resistive loads like lighting are one thing but a pump is like a dead short.
I would recommend switching over to a more commercial timer like the Intermatic T-101.
You could add a receptacle to that for your pump. You could add a cord and receptacle and use that plug-in if needed.
