Power Status Indicator
Old 05-03-19, 02:40 PM
I'm a control freak. I'm installing an attic fan that is powered through it's own thermostat. I want a way to know when the fan is running without having to crawl into the attic.
Is there anything that exists out there that I can implement that would tell me when the fan is running? Some type of wifi "hey i'm on" thingy?
I am considering running lines to install an on/off switch in the house so I can kill the fan when I don't want it on, but this would all happen before the thermostat so I still wouldn't know if it's actually running.
Old 05-03-19, 03:39 PM
Received 4,046 Upvotes on 3,630 Posts
Welcome to the forums.
CR Magnetics makes an easy to use sensor. It comes with a little coil that the hot wire for the fan runs thru. It lights up a remote red LED.
Remote current indicator
An alternate way to do this is to use a small AC transformer that gets powered when the fan comes on. Then you could wire in a remote LED to it.
mattylynn voted this post useful.
Old 05-06-19, 11:36 AM
Thanks so much for the reply. I'll give this a try.
