Smart switch wiring with three black wires
Old 12-27-19, 08:10 PM
R
Lightbulb Smart switch wiring with three black wires
Hello,
I am trying to replace my single way toggle switch with smart switch.
When i opened my old switch, i noticed there are three black wires (two snapped in/inserted in back of switch and one black wire on side top screw).
After researching on google, i understand maybe top two (inserted and screwed on side) are pig tailed live wires and one snapped in bottom is load wire.
Also i was able to find white neutral wire.
But there is no green ground wire but i can see naked wires in the back of metal box.
How do i wire my smart switch which required white (got it), black (live hot), red (Load) and Green (ground) wires.
Thanks in advance
Old 12-28-19, 12:44 AM
Received 1,330 Votes on 1,229 Posts
Welcome to the forums.
The black wire attached to the upper screw and the black wire pushed into the upper push-in location are your hot wires. They need to be combined. If the new switch doesn't have wires on it you will need to add a short tail to the two black wires. The remaining black wire is the load/light. The neutral would be the splice of white wires.
Raj Sethi voted this post useful.
Old 12-28-19, 02:29 PM
R
Thank you for the reply.
New switch comes with wires.
1. Can i join wire from new switch and these two hot wires all together?
2. there is no ground wire in old switch but i can see bare wires in box itself. can i just join new wire from those bare wires and use it as ground for new switch?
Old 12-28-19, 02:59 PM
1 - yes
2 - yes
A bare wire is a ground wire.
Old 12-28-19, 04:42 PM
R
Awesome.
Will follow the same.
Thank you for your help.
