Flimsy Samsung TV Stand
I just bought a 50" Samsung 4K HD TV and I'm questioning the design of the 2-piece stand. The pieces don't sit flush against one another and therefore is impossible to tighten fully. Regardless of how much I tighten the screws, the base swivels when applying pressure. As you can see in the images below, the top piece has four holes that are essentially flush, but the bottom piece has two holes with spacers that protrude about 1/8". This is what is preventing the pieces from sitting flush and causing the stand to he unstable. I can't for the life of me understand why it was designed this way.
It looks like there is a latching tab on the curved side. Try inserting the tab in the slot of the base and rotate the top down onto the base then install the screws.
I have noticed that the new generation of TV's seem to have flimsy basis. I think it's because they are so much lighter than those of 10 years or older. It's strongly recommended that you secure the TV to a back wall by mounting plate or tether with guy wires.
I got a 48" TV a little over a yr ago and while the base did seem flimsy, my biggest concern was how light it was so I attached 'guy wires' to the back to make sure it won't inadvertently get knocked off of the the table.
