DVD player reads "Cannot Read Disc"
So I gotten this message in my living room DVD player on a couple of occasions.
I am able to view many other discs with no problem. When I insert that same disc into my computer it fires right up with no problem. This has only happened recently. I have made sure it was seated properly and cleaned it etc. Is the DVD player slowly dying?
Any ideas or suggestions?
thx
thx
Is it a manufactured disk, or a copied disk? We have to "finalize" all DVD's and CDR's we use at church, since the re-writable feature will prevent it from playing on other units. All our recording equipment has a "finalize" button to close out the disk and make it non-re-writable.
Yes a Manufactured Disc!
Its a Library disc. After viewing it on my laptop, there were a few spots that were not readable/froze spots that needed to skip over. I have seen worse scratches.
I believe this may have been enough of a reason to make it non readable? not sure just an educated guess.
thanks
thanks
Yeah, I have to assume it might have been burned incorrectly. If you can still make a copy of the DVD, make sure it's closed/"finalized" after the burn is done so you can't keep adding information to it, since a lot of DVD-RWs won't read right in DVD players if they're still expecting more data, if that makes sense.
