Looking for under cabinet TV
Looking for a nice under cabinet TV. It should be a simple task but for whatever reason I just can't find one. It almost seems like new unites are not longer made. All I see online are older models and when I get to a specific online vendor to perhaps buy it, it is either out of stock or no longer available.
Am I missing something? Is this product no longer wanted by consumer?
Thank you.
Thank you.
Only problem with a mount is that it is really hard, or even impossible, to find a small (13", 15") TV that fits under a kitchen cabinet.
Depending on what you want to do with it, you might want to consider finding a computer monitor with HDMI inputs. It might be a little more work to mount and get it connected to your cable box or anything - and you'll probably have to buy better external speakers since most PC monitors don't have speakers, or the ones they have are bad - but this might be the easiest way to find the size screen you need.
I have a 22" LCD screen under my kitchen cabinets on a swivel wall mount. I can push it against the wall or pull it out and swivel it. The wall mount runs around $25.
A 15" or 16" LCD monitor can be purchased for around $100.
I originally started with a 15" LCD but it was too small to see from the far side of the kitchen table so I upgraded to a 22" Samsung TV. Hugging the bottom of the cabinets allowed approx 5" between the TV and the countertop.
Using google and searching for "under cabinet TV's" I found many available. A few carried by Walmart.
