How can i build a 15 inch amp?
Old 10-13-16, 07:52 AM
K
Hi guys, I found a speaker box for a 15 inch speaker in a container yesterday.
It would be cool to build an amp out of it with a tele and an xlr plug.
How do i turn it into an amp? Its okay if it only has a power on and a volume control.
thankful for tips.
Old 10-13-16, 08:01 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Thread moved to home entertainment.
Do you have a speaker and an amplifier?
Old 10-14-16, 02:07 AM
K
Thanks for moving it.
I wanna get a 15 inch speaker. is there some stuff i can order online to make it an amplifier?
Like i build it into the box. Just some simple stuff, i just wanna see how it works.
And it would be really cool if i could have both a tele plug and a xlr.
Old 10-14-16, 03:02 AM
ray2047's Avatar
What would the amp and speaker be used for? Most sound systems are stereo and require a minimum of two speakers.
Frankly what you show in the picture isn't worth much without a speaker and you would probably be best just buying what you really need but you need to tell us what you need it for. Is it a PA system?
Old 10-14-16, 04:13 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Note: OP is located in South Africa.
Kefflon, you have a box. That's it. You would need an amplifier and speaker. There may be sources in your area, but finding periphery that will fit this box may be a challenge.
K
I wanna use it for voice or guitar or other instruments.
To me its okay if its just 1 speaker. And the quality of the sound is not important.
The ideal would be if i can have a xlr input for a mike and a tele input for other instruments.
and if i could connect it to a PA to hear myself when I'm on stage.
I just need basic stuff, would be nice to build something just to see it work.
Old 10-14-16, 04:30 AM
K
I went to a shop now and i see its a box for 12 inch speakers.
I can buy a speaker there, but the rest i think i have to order on eBay, since I'm in Namibia.
Is there DIY kit for amplifiers that i can fit in the box?
Old 10-14-16, 04:46 AM
chandler's Avatar
How much electronics experience do you have?
Old 10-14-16, 05:47 AM
ray2047's Avatar
Old 10-14-16, 09:05 AM
E
I went to ask my husband about this (since he's been a musician since he was like 11) and he told me to tell you that this wouldn't really make a good box for a guitar amp. Guitar cabinets have to be designed a little differently to vocal amps, PA speakers, or stereo speakers, which is more what this looks like. You'd have to cut new inputs for it, you'd have to seal it a lot better, and it would require a lot better speakers than what you might have access to.
Honestly, you're better off just using it for like a PA system or as one-half of a home system, but...that's gonna take a lot of work, and all you've got right now is a box.
Old 10-26-16, 05:48 AM
K
Thank you guys.
Yes, I think the box belongs to a car speaker.
Its probably not the best for an instrument amp, but I just wanna see if it works, if I buy a diy kit and connect it to a speaker, and make room for inputs and controls in the box.
I don't have much electrician experience, but its fun to try things.
Anyone know of a diy kit i could use?
