Subwoofer volume issue
I have an older Polk subwoofer, issue is the volume control is a knob, but works like a toggle now. It is either off or if I turn it up a little it is full blast and shakes pictures of the wall.. Does anyone know if this an easy fix or not??
Thanks!
Thanks!
It might be as simple as a bad rheostat. You might get lucky spraying it with contact cleaner but a replacement should only be a few dollars. First step is to open it up and try to see if there are any numbers on it or if it can be identified.
I have a polk sub with a vol knob. I'm not going to take mine apart, but the Infinity sub I had before that had all knobs and components sealed inside. I had a knob issue on that, and was unable to use any contact cleaner or replace it. I put an ad on a FB local swap and sell site and someone bought it for $20. They said they would prob find an amp panel of similar size and rig it to work. I paid a lot for it back then, but I guess it lasted 15 years.
Most potentiometers & sliders will get scratchy & cut out if not moved for years. Sometimes just tediously rotating it dozens of times will clear it up enough to use. 40 years ago when I repaired stereo gear you could get an adapter that screwed onto the end of the control mounting shaft, then cleaner spray could be forced past the shaft & inside. I don't know if these are still available & I always found a way to get spray into them from the back.
Great advice! - thanks! Will try the cleaner first since that is the easiest.... will be sad to see this sub go, been great for 10+ years...
