Noise coming out of wall mounted tv wall
I mounted a tv today and every time I move the stand it makes a noise like a nail coming out of a wood. It not as loud but Im still scared to put my expensive TV on it. Is the noise ok??
You have to find out what/where the noise is and only you can do that.
If you mounted the bracket properly and it is rated for your TV weight then it should be OK but until you determine what is going on I would not trust it.
Move the bracket while putting some downward force on ot and get someone else to check if the bracket mount plate against the wall moves or the wall itself.
