Construction cost question
Hello. I'm planning a pole barn "house". The external shell and concrete slab costs are very easy to obtain. The inside framing and what not is, apparently, very difficult to obtain. I can't even get a ballpark price per sq foot for builder grade so I can't effectively plan. Does anyone have a clue as to even a rough price per square foot for the interior part of this type of structure?
Thank you.
Thank you.
Standard practice is three or more bids from local contractors so you can compare. Are you saying the contractors are refusing to bid the job?
Thank you for your reply. Nobody is refusing the job, but I can't even get a ballpark guesstimate on the price per square foot to see if this is even a viable option. They can tell me for a traditional stick built home a rough price per sq ft, but this isn't a traditional home of sorts. I have a basic plan and I know the measurements, it's basically all the framing and insulation, and in from there. No siding or the like. Seems odd o can't even get a ballpark number.
In my mind you would bear almost the full expense of constructing a pole barn and of building a house. Even though you have a pole barn you don't have footers and and foundation that would be required for a home. So, I'd figure closer to the cost of building the two as separate structures. Any savings you might see from having a pole barn would be offset by the construction hassles of having to build a house within the barn. Then there are the zoning and permitting issues. In my area they probably would not allow it without you having a Professional Engineer sign off on the design and construction.
