What animal do I have to deal with?
Old 06-27-16, 09:53 AM
T
Received 86 Upvotes on 76 Posts
From the picture you can see an animal has taken up residence in a corner of my lawn:
Name:  Animal Mound.jpg
I have chipmunks, but this is nothing like their holes. The hole, itself, is 2 - 21/2" in diameter. The mound is wide and several inches tall. The hole is approx. 30' from a rocky, wooded area and approx. 100 yards from an area considered wetlands although seldom more than damp. I suspect a rat, but don't know.
Old 06-27-16, 10:10 AM
Received 3,338 Upvotes on 2,997 Posts
My first thought is woodchucks.
Excellent diggers, woodchucks dig both simple and complex burrow systems, whose depth and length depend on the type of soil. Most burrows are 25 to 30 feet long and from 2 to 5 feet deep, with at least 2 entrances, although sometimes more. The main entrance is often the most conspicuous, with a large mound of freshly dug dirt nearby. The other less visible entrances are used for escape purposes. A nesting chamber for sleeping and raising young is found at the end of the main tunnel; a separate toilet chamber helps keep the burrow clean. Woodchucks may have 2 burrows: a winter den, in a wooded area, that is deep enough to keep them from freezing, and also a summer den, in open flat or gently rolling areas.
from ct.gov
Old 06-27-16, 02:38 PM
T
I found more, at the base of my foundation. It's on a slope so I'm concerned about erosion. Is there a solution other than killing them? I used a mixture of detergent and castor oil that worked for moles and I'll try that tomorrow. Any other suggestions?
Old 06-27-16, 02:44 PM
Shadeladie's Avatar
Super Moderator
Received 341 Upvotes on 272 Posts
I'm pretty sure rats don't dig holes underground. Not sure if a woodchuck is the same as a groundhog, but groundhogs would be my guess. I have holes all over my back. I think you have to bomb their holes closed to chase them away, but they always come back.
My last dog used to wait for them, catch them and kill them, but not all dogs do.
Old 06-27-16, 03:00 PM
Received 1,182 Upvotes on 1,140 Posts
I have a gopher problem and their mounds look a lot like that.
Old 06-27-16, 03:18 PM
Received 722 Upvotes on 633 Posts
My stepson has a rat problem where they have tunneled under the road from the farm on the other side.
Old 07-04-16, 09:50 AM
P
Received 88 Upvotes on 81 Posts
Seems to big for a rat but you never know. Could be a young groundhog (woodchuck). They are leaving their mothers right now and looking for harborage.
Old 07-04-16, 04:27 PM
B
Received 44 Upvotes on 40 Posts
One of the trail cameras would sure make identification easy. Rent borrow or buy.
Bud
Old 07-05-16, 08:36 AM
B
Received 13 Upvotes on 9 Posts
Badger?
Do you have badgers over your way? Brother saw two of these playing in the road then they headed for home.
Old 07-05-16, 10:35 AM
D
Received 186 Upvotes on 149 Posts
I'm with stickshift... I would suspect a Gopher. That was my initial thought.
