Insulation advice..
Insulation advice..
I have a two family being remolded right now, I need advice on insulation. I got pricing from two companies and need help in selecting the best option:
1st quote = $10,650
Roof Line
BASF Spraytite 178 Closed-Cell 6" R-41.40 at dormer ceiling
Slope to Plate
Exterior Walls
BASF Spraytite 178 Closed-Cell 3" R-20.10 at 2nd floor
Stairway Walls
BASF Spraytite 178 Closed-Cell 2" R-13.40 at 2nd floor
Blockers & Runners
BASF Spraytite 178 Closed-Cell 3" R-20.10 in basement
2nd quote = $8,000
Roofline - spray from eaves to ridge. Install R-36 5" thick closed cell foam.
2nd Floor Walls - This includes the "cheek" walls. Install R-21 3" thick closed cell foam
NSI to seal around window and door jambs with low pressure canned foam and/or latex caulk.
Basement is Extra:
Basement Rim Joist - Install R-21 3" thick closed cell foam in rim joists of basement, sealed to top of foundation wall.
Install code required DC 315 Spray Applied 15 Minute Thermal Barrier over closed cell foam
BASEMENT PACKAGE TOTAL: $1,822.86 (Package Is NOT Included In Total)
GrandTotal
thank you in advance!
opers13
1st quote = $10,650
Roof Line
Slope to Plate
Exterior Walls
Stairway Walls
Blockers & Runners
2nd quote = $8,000
Basement is Extra:
GrandTotal
opers13
Just some one line thoughts.
How many days do you need to stay out of the house while this cures?
Be sure you get their certificate of insurance and that is has enough coverage in case the foam job stinks. Some end up with smell problems and that can be especially bad if it is a rental. Also bad if all the foam has to come out.
Not a pro on foam, but in most cases 6" needs to be applied in 2 or more lifts, not all at once. Guidelines may have changed, check the mfg.
With that much foam you may have an air exchange issue and need to address that with an air exchange unit (HRV or ERV) or programmed exhaust fan.
If heat or hot water is a naturally drafted combustion unit then the house needs to be tested to see just how tight it ends up. Same testing is used to determine your fresh air requirements. Not sure how strict these rules become if it is a rental unit.
You seem to have already decided on foam insulation, but if you want more input, Google "Richard Beyer foam insulation problems". He explains it better than I can.
All spaces inside the foamed envelope need to be conditioned, heat and ac.
Bud
Bud
