attic air sealing and vapor barrier
Received 0 Votes
Hi,
I'm currently working on an old attic that looks like it's been properly air sealed and is filled with loose blown in insulation, but after a short inspection, i noticed there is no vapor barrier. Any recommendations on whether I should install a vapor barrier? I was thinking of moving the insulation and putting on an polyethylene vapor barrier, then putting the insulation back.
Thanks
Thanks
Instead of installing a plastic vapor barrier I'd coat the ceiling with a vapor retarding primer sealer. Easier and possibly more effective since there won't be any voids if you cut the plastic for the joists cavities and a LOT easier than going up/down over the joists.
With a location in your profile someone may well know if you even need a vapor barrier.
Just as important is to have proper amount of insulation and roof venting.
https://www.energystar.gov/index.cfm...sulation_table
Just a wild guess, but mine would be that at least 99% of the homes built in the last 50 plus years have no vapor barrier and there just fine.
