Re-insulating existing skylight
Old 01-31-17, 04:28 PM
B
Because of high energy costs I am adding insulation to my attic to bring it up to R-38. I have an approximately 6-8 foot skylight (from ceiling to roof) with and irregular shape (trapezoid from ceiling to roof, 2x4 framing) in my attic that currently has R-11, faced, fiberglass insulation. Some of the insulation has fallen off or appears dirty with probable air leak. I would like to add insulation and bring up the R value of the skylight. In researching, there appears to be 4 options:
1) repair existing insulation, wrap skylight to prevent air leaks
2) replace existing insulation with higher R-value faced insulation, with or without wrap
3) repair/keep existing insulation, cover skylight with foam board insulation with foam sealant at board interfaces.
4) repair existing insulation and seal air leaks, over wrap with unfaced higher R-value batt or rolled insulation, although with the irregular shape, I don't know how I would keep the insulation in place.
Any suggestions by someone with more experience than me would be appreciated.
Old 01-31-17, 04:33 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Welcome to the forums! Being a vertical surface it may be difficult to get regular insulation to work correctly. I am for door #3, with the exception that I would go ahead and spend a little money and apply 2" of foam board and tape all intersections and foam where it meets opposing planes. Since this is in your attic, you don't need a great deal of fiberglas, and heat rises, so most of it will stay in the tube, anyway.
Hang in there as others will have more information and possibly different solutions.
Old 01-31-17, 10:57 PM
B
Thanks. I noticed there are several types of foam board insulation. Any particular type that would work better in this situation?
Old 02-01-17, 03:17 AM
chandler's Avatar
Old 02-01-17, 04:23 AM
B
Received 37 Votes on 34 Posts
Here's an article that might be helpful. Air sealing will be important and this article shows many locations to focus on.
Insulated Skylight Shaft
Bud
