Advice on insulating my garage
Hi. First post here. I have a split level home where approximately half of the lower level is a two car garage. The outside walls are concrete. I am in the process of installing an electric heater so I can work in the garage in the winter. I have long wanted to do something about insulating the concrete walls but I don't want to lose much interior space. I was thinking about just installing some rigid insulation and sealing all the gaps. There's just not enough room to do a full framed wall. What do you think would give me the best bang for the buck? The concrete is partially below grade along the back wall. Would I need a vapor barrier? I'm attempting to attach pictures. Sorry they were taken at night.
With any insulation project it is the first layer that makes the biggest difference. Add 1" rigid (r-5) to bare concrete and it makes a big difference. Add that same 1" to an already insulated (r-13) wall and it is a waste of money (almost).
One issue with rigid foam insulation is the need for a fire rated thermal barrier, usually 1/2" drywall. One brand has been tested and approved to be left exposed without an additional covering, Dow Thermax. It is hard to find and a bit more expensive, but it eliminates the drywall.
Some details to work out, but rigid insulation would involve the least amount of space as you stated. You might be able to glue the rigid to the foundation and after it is solid glue the drywall to that. Add a few fasteners through to the concrete to be sure and done.
Bud
Bud
Go add up the cost of the rigid insulation vs a simple stud wall with insulation and there wont be a big difference.
Granted you will give up a few more inches, but the stud wall with R13-19 will be the most efficient, look better, and give you a lot of space to easily hang items .
narrow framed wall? 2x2 studs?
No requirement/benifit to do anything to the floor,
Firing strips, 1x2 material attached to the wall directly, then a sheet of insulation then another firing strip.
No vapor barrier, different situation, external wall no moisture.
Thanks again for the advice. I'm not planning to add any more electrical outlets than are already present... I have a few already installed in the ceiling. I just saw this video on youtube and it looks like the perfect solution. Hopefully I can get started this weekend. I'll try to remember to post some pics...
https://www.youtube.com/watch?v=oKQd...YCEk0ZQ4gP0RlA
I just thought of something.. I want to install peg board to the back wall... Not sure if those furring strips on the outside of the foam insulation will end up being good to hang stuff from. Maybe I'll add some 2x4 studs placed against the wall "sideways".
The house was built in 1979. I haven't changed anything since I bought the house in 2002. Not planning to rip it out now. Passed inspection before I bought the house. Nothing noted by my home inspector. Pretty sure what I have is legit.
Also known as furring strips
Fir: is any genus (Abies) of north temperate evergreen trees
So I know what I'm hanging my drywall from!
Well like I said the electrical has been that way for at least 15 years and likely closer to 35 with no issues. I'm not here to make a bunch of more work for myself.
As for not orienting 2x4 studs sideways then I guess I could use 2x2 studs. Remember I'm trying to conserve interior space.
Received 38 Upvotes
Any NEW electrical work must comply with the current code enforced in your jurisdiction. It does not matter what the code was at the time of the original construction. Generally speaking, the closer you are to a large population center (inside city limits) the higher the likelihood that a permit and inspection will be required for any electrical work.
Haha well I've seen some pretty hairy boards in the lumber yards around here but pretty sure that's not why 'furring strips' is spelled the way it is.
