Exterior widow closeup insulation needs
Old 12-28-17, 07:29 AM
K
I have 2 windows that are 6 inches high by 36 inches long under the kitchen cabinets above the base cabinets. The windows are double pane sealed units and do not open I would like to close up these windows and cover with tile
Can I just fill the cavity with insulation then Sheetrock the openings closed ? Since the windows are behind a large shed it would be hard to remove the glass windows and replace the siding
If I can just fill the void with insulation do I need a vapor barrier ?
We live in Phoenix so humid is low and heat is the problem not the cold as far as insulation goes and suggestions would be appreciated
