Insulating Junior Beam Construction
Old 04-05-18, 08:10 AM
I live in an 82 year old house with a basement. The first floor is made using junior beam construction -- steel i-beams set about 30 inches OC with poured concrete about 4 inches thick. The i-beams are about 10 inches in height which creates a stud bay about 6 inches deep under the floor (on the basement side).
Part of the floor is over an unconditioned integral garage. The room above the garage is conditioned. I live in a zone 5 climate. I'd like to use Roxul rockwool batts which have a 5 1/2" thick batt.
Should I install a vapor barrior on the cement side of batts?
I'd appreciate any other advice on the installation as well.
Old 04-05-18, 10:05 AM
Received 1,267 Upvotes on 1,207 Posts
Nope but air sealing over a garage is critical.
