Foam board + backed fiberglass insulation -- bad?
I've installed foam board along the exterior walls of our basement where I'm building a guest room. I've framed the 2x4 walls along the foam board. Soon I need to insulate those walls.
I bought insulation already but it has a backing. Now I'm thinking I should have got non-backed so I don't create a "vapor trap" between the foam board and sheetrock.
Should I use what I have?
3/4" foam board. Exterior walls are 3" brick + 8" cinder block. Foam board is being used as a thermal break as well as vapor barrier against the cinder block. I built out 2x4 walls after that, and filled with R-15 insulation (removed the facing). Yes, it is XPS foam.
