Insulation existing interior walls for sound?
Old 10-27-19, 09:28 AM
Hello, for our two upstairs bathrooms, I was wondering about options to insulate a few key walls for sound? There are some real sound issues coming from a couple of walls.
Can I blow in some insulation or would removing the drywall and installing batts of mineral wool be the best?
I see there is now blown-in mineral wool...would this be better than cellulose?
Unfortunately we really can’t add another layer of drywall without doing some major changes as the space is limited.
thanks
Old 10-27-19, 12:28 PM
XSleeper's Avatar
Received 712 Votes on 659 Posts
You are limited in what you can do with a 2x4 wall. The amount of difference you will see between different types of insulation is quite limited by it being only 3.5" thick. Is there a big difference in insulation? Yes. You just won't notice a huge difference with so little thickness. So I wouldn't fret about what to use too much.
If you won't be removing drywall to insulate, blow- in is your only option. Adding density alone will probably be your best bang for the buck. What type probably is pretty immaterial. I would probably just use cellulose.
