Removal of Blue Lily Turf- advice on how to fill
Old 02-14-16, 11:46 AM
A
Hello,
I recently removed a large chunk of blue lily turf in a natural area in my yard because it was taking over the grass. I may have went overboard... and now have a large space to fill.
I will be at least mulching this area. I am looking for ideas on low maintenance plants that may add some color and do not detract from the hydrangeas (?) behind it
I am not a huge fan of putting another ground cover down, because i want something more uniform.
what are your thoughts? Thanks for the help in advance.
Old 02-14-16, 04:27 PM
P
Received 2,152 Upvotes on 1,927 Posts
I don't know what you are expecting if a ground cover is not uniform enough. Maybe we should start with your idea of a ground cover and what you want in that area.
Without knowing anything I'm thinking of a vinca. It's a ground cover and it spreads but it is not as invasive as many ivy's. When established it can form a dense uniform mat of vegetation that flowers in spring so you have a blanket of color before the hydrangeas flower.
