Is this a weed or just different type of grass?
Old 04-21-16, 04:23 PM
N
Received 1 Upvote on 1 Post
I'm in CT, 06611, and generally have a mix of bluegrass, ryegrass and fescue (I believe). Not sure if this is a weed or some other kind of grass. Also, it's only popping up in some bad/patchy areas.
Thanks for your thoughts.
Last edited by PJmax; 04-21-16 at 05:45 PM. Reason: removed duplicate pic - added two more
Old 04-21-16, 05:02 PM
XSleeper's Avatar
Received 1,810 Upvotes on 1,628 Posts
If the stem is noticably triangular shaped, it's a type of sedge.
Old 04-21-16, 05:30 PM
N
Thanks. I'll look into that. Also here's a slightly bigger photo:
Here's a slightly bigger image size: http://i.imgur.com/pGiNEgc.jpg
http://i.imgur.com/q34Wvnh.jpg
http://i.imgur.com/nGF77c8.jpg
Does that help?
Old 04-21-16, 06:13 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Looks like quack grass
Old 04-23-16, 10:26 AM
N
So this stuff is now popping up like crazy (was just a little bit when I posted the other day). Below are some more detailed pics. Sedge, quack grass, something else? Thanks again!
larger/detailed pics
Old 04-23-16, 10:47 AM
XSleeper's Avatar
Old 04-23-16, 10:53 AM
N
Hmm. Guess my Lesco Dimension didn't do the trick
Old 04-25-16, 07:30 AM
N
Any chance it could be stiltgrass rather than quack or crab?
I guess I should just pull some and bring it to local garden center...
Old 04-25-16, 10:39 AM
XSleeper's Avatar
It looks nothing like stiltgrass.
Old 04-25-16, 12:10 PM
N
Ok thank you. A neighbor thought that's what it was...
Old 04-27-16, 08:45 AM
N
Could it be Nutsedge?
Here's a pic of mine:
Compared to this:
found here: Yellow Nutsedge (Cyperus esculentus) in Greater Depth - eXtension
