Retaing wall over culvert ppe.
Old 06-29-16, 07:46 AM
NorPlan's Avatar
Nine years ago We had widened the Laneway and put up a Retaining Wall over the Ditch entering the Property.. @ That time we used (True 8X8 Timbers) 10' Steel Fence Posts to Support the Fence.. Exploring Avenues to take with the Minimum Expense $$ as Time / Age has shown itself Today on the Retaining Wall ..lol... The Dept. of Highways in our area have done a number of projects , everything from Wire Baskets filled with 4" Rock, Foot Square Interlocking Brick, to Full Sized 2 ft Square Cement Blocks.. The Ditch is 4.5 ft deep in the centre to 13 ft from Roadside to Propertyside.... Have thought of the option of a Poured Concrete wall but Canadian Winters can leave a possible Crack... Thoughts & Opinions Welcome.. Cheers
Old 06-29-16, 08:25 AM
C
Received 2 Votes on 2 Posts
Can you post a picture of the wall and area so we can see what you see?
http://www.doityourself.com/forum/el...-pictures.html
Old 06-29-16, 08:46 AM
P
Received 620 Votes on 573 Posts
I'm a fan of dry stack retaining walls made with pre-cast concrete blocks. The proper "engineered" systems install quickly and accommodate ground movement very well. I mostly use Keystone tri plane Compac blocks but there are other brands out there.
Old 06-30-16, 01:02 PM
NorPlan's Avatar
@Carbide Tipped... Sorry sending from iPad Only.. Unfortunately Lacking in the TechNo where with all to (Copy / Paste), can only go as far as taking picture.. 😩🤔
