Drip irrigation leaking
Received 0 Votes
Hi,
I am getting my drip irrigation system (simple 2 zone) back up and running for the season and the system seems to be leaking in a place that is a new leak to me! It is leaking below the regulator and adaptor - where the system connects to the drip tube (not the distribution tube). I think I used the correct terms there
. In the picture the leak is happening in between the silver fastener and the gold valve(?).
I can't seem to figure out what to do so any help would be much appreciated!
thanks!
[ATTACH]79617
thanks!
[ATTACH]79617
You will need to re do the joint if tighting the clamp does not fix.
Try heating up the hose before installing, I use ay propane torch to warm up the pipe, slip on, then clamp while warm.
