Patio Umbrella - Missing Spring
Old 06-06-17, 09:39 AM
C
I have a patio umbrella from Target and that I just went to setup for the summer when I noticed that one of the springs that connects two of the ribs is gone.
Here is a pic of the ribs with their missing spring:
Name:  Missing Rib Spring.jpg
Here are some pics of working ribs with their spring:
Right side
Name:  Spring - Right Side.jpg
Bottom
Name:  Spring - Bottom.jpg
Left Side 1
Name:  Spring - Left Side.jpg
Left Side 2
Name:  Spring - Left Side 2.jpg
Anyone know if this is a generic part that can be bought from a store or ordered online? If not, or these are proprietary to the umbrella, any ideas on what I can do to fix this and connect those two ribs?
Thank you
Old 06-06-17, 10:33 AM
P
Received 2,009 Upvotes on 1,801 Posts
That is a special part just for that umbrella. I seriously doubt you will find a replacement. I would use a long bolt and nut as a replacement.
Old 06-06-17, 10:37 AM
Received 800 Upvotes on 703 Posts
Nut and bolt was my thought also. IF it has to have some give - maybe a heavy duty zip tie.
Old 06-06-17, 10:39 AM
C
Received 144 Upvotes on 117 Posts
I think you might find a torsion spring that would do the trick, you could use a nut and bolt as the pivot point for it.
McMaster carries a wide variety; you should only have to get close. And you will have to cut the ends to length and form the little bend on the ends.
https://www.mcmaster.com/#torsion-springs/=17yb2h7
Old 06-06-17, 12:05 PM
C
Pilot Dune/marksr, thank you for the Nut/Bolt idea. I'm going to try this short term as I have the parts in my home and can test it out soon.
CarbideTipped. thank you for naming what that part looks like. I'm assuming it was a torsion spring that was fastened with some type of rivet. The combination of a replacement torsion spring secured with nut and bolt sounds like a great combo.
I'm going to measure springs that are working to compare to the listings on that site. The only thing I may need to figure out is what Deflection Angle (90, 180, 270, 360) to select.
Old 06-06-17, 02:10 PM
P
Since most umbrellas don't have springs at the joints I'll say it's really not needed. Most umbrellas use a winch or pin in the center to hold it open. The springs just help make it easier to open. Since you are only missing one you'll probably not notice that it's gone.
Old 06-07-17, 05:27 AM
the_tow_guy's Avatar
Received 212 Upvotes on 170 Posts
Just an additional suggestion when you nut & bolt it - use a self-locking nut so you can leave some freedom of movement but still keep the nut in place.
Old 06-07-17, 02:30 PM
P
And slide a flat washer or two on the bolt between the two tubes. This will allow them to pivot without rubbing against each other.
