Leaking sprinkler head
Old 10-28-17, 05:11 PM
L
Received 1 Upvote on 1 Post
We have a 4 zone toro system. Everything works fine but zone 4 leaks out of the heads forever. Yesterday I opened all the valves and everything looks fine. Over time I have replaced many heads with RainBird SAM heads,, but that is getting expensive. New valves / new solenoids - still leaks. What next ? Thanks.
Old 10-29-17, 04:41 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Most likely dirt in seals of valve. Take top off and clean. If valve body is scored than valve will have to be replaced.
Old 10-29-17, 04:48 AM
P
Received 1,756 Upvotes on 1,569 Posts
If there is no dirt inside the valve I would first try replacing the diaphragm. While you have the valve body opened run your finger around the surfaces where the diaphragm touches feeling for the scoring/scratching that pugsl mentioned. If it feels smooth I would would just try a new diaphragm but if you feel that the body has been eroded/scored away then it will need to be replaced.
Old 10-29-17, 06:00 AM
Marq1's Avatar
Received 1,098 Upvotes on 998 Posts
Are the heads below the valve such that all the water in the line is leaking out till empty of is the leaking water constant?
