Planting grass over sand/gravel
I have attached some photos of my current driveway. I will be removing the green wall (was there to limit toys/balls from going to the woods).
Property is sloped as the water runs from the left of the house onto this area, and water from the beginning of the driveway drains to the left of the shed.
Curious to see your thoughts on proper drainage system to prevent damage to new grass which will be planted in the spring.
Would it be ideal to dig as much sand out, plant topsoil throughout, plant grass, and install some loose pebbles or gravel around the edges to cause any water to flow away from the grass?
You should remove the sand and gravel and bring in topsoil, then plant grass. Unless you want to get fancy with diversion ditches I would not bother doing anything special for drainage except properly grading the new lawn area.
Sun rises across the street over a lake...plenty of sun throughout the early day.
