Fixing sprinkler valve—please help!
We are not handy people, but we tried to replace our sprinkler valves with instructions from an employee at Lowe's and lots of YouTube vids. We thought all went well until turning the water back on—leak. It is a small, steady stream coming from where the adapter screws into the valve. We did not use plumbers tape as none of our instructions said to, though now that seems foolish of us.
My question is: is there any way to stop the leak without repeating the whole process of cutting the pipe and replacing the valve with new adapter? Something we can apply over the top without taking it all off just to add plumber's tape?
Welcome to the forums.
That type of fitting usually works best with teflon tape. There really isn't a product that will seal the leak from the outside reliably. There are some miracle putties that you could try but it's a crap shoot.
This is a AH HA moment in your DIY trek, you will never do this again!
Joint has to come apart, teflon tape of joint compound needs to be installed on the threads, then you'll bask in the glory of a job well done!
Marq1 is absolutely right but...
It's a sprinkler system--intermittent use
It's outside--won't cause any damage
It's a small leak--not too wasteful (and will benefit any plantings nearby)
It's not a focal point--so ugly may not be an issue
A fat "O" ring cut and snugged into the groove between the valve and the fitting, held in place with a band clamp might work. Maybe also some Miracle Tape between the O ring and the clamp.
but...
