Grass seed for wet shady area
Old 10-01-19, 06:15 PM
I
Received 1 Vote on 1 Post
I have a small pasture that gets brush hogged about once a month. I have some spots that the grass won't grow in because of the shade and moisture. Anyone have any ideas
Old 10-01-19, 10:59 PM
Marq1's Avatar
Received 529 Votes on 489 Posts
Regardless what type of seed is used (shade/sun) grass still needs some sun. If the area is dense shade then it's going to struggle.
Same with water, a good thing until there is too much so getting it drain correctly is going to be needed!
Old 10-02-19, 04:59 AM
P
Received 960 Votes on 882 Posts
Do you have animals in the pasture? Are they the reason you don't have grass in that area?
Some varieties can tolerate (but not thrive) shade better but at heart all turf grasses are full sun plants. If you don't have grasses growing in a shady, wet area then I wouldn't bother with seed as Mother Nature is pretty good at putting a plant anywhere it's capable of growing. But... you can try. It's only grass seed so you won't be out too much money.
Old 10-02-19, 06:09 AM
W
Received 36 Votes on 33 Posts
You could thin out some of the tree branches to allow some sunlight under the trees. Grass needs sunlight.
