Noticed this on my anti siphon valve. I assume it might just be a leaky gasket but wanted to get the thoughts of the community. Whats odd is that when I run via my Rachio I dont see anything coming out so unsure what happened since I cant seem to reproduce it. Any chance I can repair this? Or likely need to replace completely? Thanks
Hi All, Not sure if this is the best spot for this so bear with me and if it's not maybe someone can refer me to the correct area. We need to remove several hundred sq. feet of brush from an area in our back yard. Not sure how to describe it but it contains lots of brush with your typical hard stems in the range of 1/4 inch to maybe an inch or so. Getting the brush removed down to the ground isn't the issue. What we also want to do is keep the stuff from growing back. I'm assuming that there are certain eradicating sprays (etc.) that will work, but what is the best thing to use so as not to piss off Mother nature (or the neighbors) too much? Any suggestions would be appreciated. Thanks Read More
I would like to make some concrete garden edging and a concrete birdbath. I'm trying to search for how much remesh and what size is needed to properly reinforce the concrete. I've searched but am not finding anything useful. Is there a rule of thumb or some resource that I can access to help with this?Read More
