Mysterious Water Flow in Sprinkler Zone
Old 09-10-23, 03:15 PM
G
Received 2 Upvotes on 2 Posts
Hello Again,
I'm just stumped with this so I thought I should ask.
One sprinkler zone trickles water when off. Its not the line draining as I already tried draining the line. I then replaced the entire valve. Still trickles. The only thing that makes it stop is to turn of the sprinkler main.
Did I really replace a bad valve with a brand new bad valve?
Old 09-10-23, 04:15 PM
Received 3,897 Upvotes on 3,494 Posts
I don't know....did you ?
If you know what zone it is.... then only that valve could cause the problem.
Old 09-10-23, 04:19 PM
B
Received 288 Upvotes on 256 Posts
Switch with a zone valve that works. If problem follows, the valve is defective.
GotToGo voted this post useful.
