Turning on outside lights on at dark?
I want exterior lights around my house to turn on at dark every night. Unfortunately, they are all on different switches.
It looks like these are the three options:
1. Install photocells into each socket.
2. Install the Honeywell direct wired timer at each switch that can be programmed, based on lat/long, to activate at night.
3. Install a smart switch and use the app to schedule on/off.
Thoughts?
Thoughts?
Skip #1. The ones that screw in the sockets never end up aimed the right way, they raise the bulbs a lot, and they often cause flickering because of reflected light. The photocells that mount separately and can be aimed at the sky work fine, but are a bigger effort to install.
#2 works very well. I have two similar timers (not Honeywell) that automatically adjust for sunrise/sunset based on time zone, not L/L. You can add an offset to account for being at eastern/western edge of zone. I don't remember if they require a neutral in the box, but they might and that may be an issue for some.
#3 Is fine too, although the neutral issue is there for sure. Probably makes the most sense if you think you will add other controlled devices down the road. I don't think I'd bother for basic dark/dawn operation.
