Three way switch problem
SOLVED! - Three way switch problem
SOLVED IT!! - The black screw terminal was in the wrong hole. I turned the Decora switch over and could faintly see "Common" stamped into the back behid a brass terminal. I just moved the black wire to this terminal (and changed the screw) so all is good now. Thanks to anyone who viewed this post. Hope you have a great day!
Hello all, I am adding three way switching to some pot lights at the stair landing.
I have followed the wiring diagram exactly as shown in option#9 on this page.
I have a 3-way dimmer in the first box (with power feed from the panel, and feed to the light coming into it). The other switch is a standard Decora 3-way switch and is the only device in the box.
When the dimmer switch is off, the Decora switch does nothing. If it is "on", then the Decora switch functions fine.
Just want to make sure this wiring diagram is correct. Is says to wire the whites together, but is pointing to the black wires (typo maybe?).
It seems like a simple thing to do. I have checked all my connections multiple times and everything is wired according to the diagram. I'm stumped!
Last edited by Vancad; 03-12-16 at 09:59 AM. Reason: I fixed it - screw in wrong place
Welcome to the forums.'
I see you here talking to yourself.
Every three way switch has some type of common terminal marking.
Good job.
Good job.
haha! - Thanks guys. That was really starting to bum me out. Oh well, now that the wiring's done, I will celebrate with a cold "beverage".
Peace to you all!
Great forum BTW!
Peace to you all!
Great forum BTW!
But the diagram you posted does not meet current code. As of 2011 the NEC requires a neutral at all switches unless a neutral can be easily added such as when conduit is used.
Meets NEC 2011:
Meets NEC 2011:
