lost power to ceiling fan wires in junction box
Old 03-30-16, 01:54 PM
W
During remodeling ceiling fan was removed for new dry wall. When I went to check wires, there is no power.
Fan was not switched, was always on unless pull chains were used
I thought junction box/power was in middle of circuit run.
There are two white wires (wired together) and two black wires (wired together.
Every switch, light, plug receptacle works as before.
Any ideas what, how to check before I go up into the attic and remove some of the sub flooring?
Thanks
Old 03-30-16, 02:12 PM
Received 94 Votes on 83 Posts
Have you checked all of the circuit breakers?
Old 03-30-16, 02:24 PM
W
yes circuit breakers not tripped, fuses good
Old 03-30-16, 02:36 PM
How did you determine there was no power?
Old 03-30-16, 03:13 PM
W
lost powere.........
used simple light up type circuit tester, spanning both sets of wires
and used very basic Klein circuit tester
Old 03-30-16, 04:34 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Test light is good for tasting. Non contact tester is not. From what you wrote the problem is probably at a workingreceptacle, light or receptacle. Start at the device nearest the fan and redo all connections then move on to the next.
