Issues with garage ballast lighting
I have four, 2' two bulb ballast lights in my garage and the tubes keep burning out after only a few weeks of replacement. I tried replacing the electric ballasts with new ones, thinking they were junk - bought from HD. But the tubes still burn out. I believe I wired them up in series, white to white and black to black.
Any ideas on why the tubes aren't lasting longer?
- By "ballast lights" do you mean fluorescent lights?
- Assuming fluorescent are they T12 or T8 or T5?
- Was the replacement ballasts magnetic or electronic?
- Do you have a good ground on the fixtures?
- Have you measured the voltage to them with the fixture on? If so what is the voltage.
Sorry yes, they are t8 fluorescent lights. The new ballasts are electronic. I did check the grounds and they seemed fine. Not sure what the voltage is as I don't have a voltage meter but maybe I'll grab one if needed.
Low voltage might cause problems with the bulb. If you buy a meter get a cheap ($8-$15) analog multimeter not a digital multimeter. Cheap digitals are more likely to give misleading readings.
Is it cold or hot in the garage. Temperature extremes can make a fluorescent lamp fail quickly.
Are you leaving them on for long periods, or turning them off every time you leave. It's starting that wears out a fluorescent light, not running. Leave them on if you are coming back soon.
Are you using the correct bulb for the ballast?
Is the ballast hooked up according to the wiring diagram?
Make sure the reflector or ballast cover is in place and is grounded. The lamp needs the grounded metal surface to start correctly.
