question about ceiling fan remote wiring
I just replaced a ceiling fan with a new model. The old one had no remote and was wired to two wall switches, one for fan, one for light. When I saw the remote transmitter wiring instructions, it seemed apparent that following them would leave me with one wall switch that would have to be on for the fan (and light) to work, and one "dead" wall switch, so I left the remote out and wired to the switches as it had been before.
Of course now the fan only works at high speed (works great though). I've learned from reading these boards that I NEVER want to put a dimmer on a fan motor, so I'm thinking of doing the following: Add in the remote transmitter wired to the fan only, and leaving the light wired to the wall switch, which I would replace with a dimmer (dimmable LED bulbs already installed).
Does that seem like the best solution?
Your solution is good. You would only need the dimmer switch because the remote could be wired always hot if you wanted to do it that way. Note if the fan has only black and white wires (no blue). Separate wiring to the light will have to be run through the fan.
Fan does have a blue wire, as did the old one, which is what makes it so easy for me, a non-electrician, to do the swap. The hot wire for the light in my ceiling is conveniently red to distinguish it from the fan power. That fan hot is wired through the wall switch; how would I wire the remote "always hot"?
It would appear that your fan uses the external remote.... meaning it gets mounted in the canopy and it's not already installed in the fan.
Connecting the blue wire to a wall dimmer is a good idea.
If you are going to use the remote for just the fan then you'll need to cap the light wire that comes out of the remote.
You said there is a switch for the fan. If you want the fan always live.... remove the two wires from the switch....connect them together and cap them.
[ATTACH=CONFIG]67378[/ATTACH]
I think I'd rather have a switch, especially if it turns the fan on at the last remote setting.
