Control multiple lights w/dimmers using Lutron Maestro
Received 0 Votes
Hello,
I have 2 sets of lights that I need to get running in my kitchen. I bought the Lutron Maestro because I read that you can control multiple sets of lights using the companion dimmers. The directions don't show you the wiring diagram for this.
The wiring info:
I have power coming into one box. There is a wire that runs to each set of lights. I have 2 3-wire romex going to the other box. How do I wire this to get these working? Is it possible?
Thanks,
Mike
The wiring info:
Thanks,
Mike
Welcome to the forums! By "sets of lights", what is that? I think you may be thinking of controlling lighting via 3 way switching from two locations. Is that right? If you only have one cable (wires are individual conductors) to each "set" of lights, they will all come on and off together. Fill us in with more details as to what you are doing.
Received 0 Votes
More info
Hi Chandler, thanks!
I have a group of 7 can lights I want on one set of 3-way switches (Lurton maestro - master and companion) and a set of 5 can lights that I want on a separate set of dimmers. Both groups of lights are on the same circuit. Can I use 2 more companions? Another master and companion? How would I wire if I have:
14/2 Power coming in from breaker, 14/2 wire to one group of lights, 14/2 wire to the 2nd group of lights in one box along with (2) 14/3 wires going to the second switch location (only wires at the second location). I appreciate the help!
Thanks,
Mike
Thanks,
Mike
You will need two dimmers and two companions.
In the one box you have.......
1) two wire feed in
1) two wire feed out to lights 1
1) two wire feed out to lights 2
2) three wire switch lines to second switch location.
So that's five cables at one end and two cables at the other end. Is that correct ?
Once confirmed I'll leave a diagram.
1) two wire feed in
Received 0 Votes
Chandler and PJmax,
Thank you both for responding. PJmax, your diagram was perfect. I really appreciate your help! My lights are up and running and I couldn't have done it without you!
Cheers,
Mike
Cheers,
Mike
