Recessed LED lighting re-model
I am remodeling a kitchen and replacing an old recessed light with a new LED recessed kit. I am also jumping two pendent lights from the recessed light. When I hooked up the new recessed kit to the exsisting 3-wire Romex the light , and flipped the switch, the light didn't turn on. I disconnected the pendent lights so that the only light connected was the can light. Still no dice. I used a multimeter on the nuetral wire and it read 9V, and the hot didn't read any voltage. I tried switching the leads white to black and black to white, nothing. Does anybody have any suggestions?
Thanks
Thanks
Tell us all the wires and connections at the switch.
Neutral to what wire?
Any voltage to what. Did you try to ground?
For function it doesn't matter. White to neutral is for safety. It will work fine reversed.
The neutral in from the panel and the neutral from the fixture are connected to the switch itself, the hot wires and ground wires are wire nutted together. I checked the hot wire at the switch and it still read no voltage, which makes me think something got dis connected earlier in the circuit.
These are multimeters:
