Light fixture wiring unmarked
Old 11-01-16, 01:51 PM
T
Question Light fixture wiring unmarked
I am trying to install a light fixture, but upon doing so realized that the wires are not the usual white/black or smooth/ridged; instead they are both clear and identical, with only very small text printed on them. One wire has black text, the other white (hopefully that's visible in this photo)-
My question is, does the text color correspond to the usual black/white wire color? I would really like to avoid taking apart the light and seeing which wire is installed in which part of the socket, so am hoping that perhaps someone has experience with this type of wire.
If I were to guess incorrectly and wired the light backwards, how could I tell my mistake?
Old 11-01-16, 02:14 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Does not matter which wire goes to white or black, will work either way.
Old 11-01-16, 02:47 PM
W
Received 65 Upvotes on 56 Posts
Checking Which One
Use an analog meter to verify the continuity between the end of one wire and the center of the socket.
Old 11-01-16, 03:23 PM
Handyone's Avatar
With lamp cord, the identified wire is the neutral. It can be identified with ribbed insulation or print.
If there's doubt, hook the most obviously identified wire up to the wide prong of the plug and visually trace it to the white wire of the fixture.
