How do I put a new switch into an old outlet?
So, my wife and I purchased a wonderful little home that was built in 1948. It was updated in the early 70s and that was the last time. We are renovating it and are currently doing the fixtures. I have two questions.
First, is that fraying in the top left of the existing outlet dangerous?
Second, if the fraying is not dangerous, can this dimmer switch be placed into this outlet. If yes, then how? Specifically where does the dimmer wire connect and where should we place the ground?
Also, I realize this is a dual outlet and yes I have two new switches. Thanks in advance for any help anyone can offer.
The fraying is actually the paper packing in the cable. Normal, not a problem.
Your switch appears to be for either single location or 3-way use. The red and black wires in the middle probably go to the wires on your dimmer. Check the instructions with your dimmer to be sure.
Ground wire is not connected.
Thank you for responding so quickly. Glad to know that there is no danger. So, the striped wire does go to the dimmer. Is it possible to plug that in to the outlet or should I take it back and just get a regular switch? Thanks again.
I'm confused by who means what by striped dimmer wire. AB, you wrote:
Which I took to mean the striped house wire but Pete meant the striped wire on the dimmer*. So AB do you mean the striped house wire in the switch box or the striped dimmer wire?
Plug what where?
*The striped wire on the dimmer is for 3-way circuit use only so is not used in your situation.
