Help hanging a chandelier
Old 02-11-17, 10:27 AM
T
Hello-
My problem is that I took down the old light over a year ago. I forgot to mark down which breaker this light is on.
How do I figure this out? I have some kind of meter that belonged to my brother but I have no idea how to use it. Can somebody pleas tell me if I can use this thing, and how to use it, to check if the wires coming out of the ceiling are hot? I am including images of wires, meter, and wires coming out of the new chandelier.
Thanks!
Old 02-11-17, 10:34 AM
Received 4,047 Upvotes on 3,631 Posts
You will use the red section labeled AC. I believe I have 250VAC circled.
Touch either probe to white and the other probe to black.
The needle will go half way up for 120VAC.
The ground connects to the short bare ground wire in the box.
The side of that black wire that has ridges is the white/neutral side.
The smooth side is the hot/black side.
Old 02-11-17, 10:40 AM
XSleeper's Avatar
Received 1,945 Upvotes on 1,746 Posts
Testing it assumes your tester has batteries that work. Turn it to 10 A.C. V. and touch each wire. But if the wall switch is off you wont have power. Switch has to be on to test for power.
You could also wire up a temporary pigtail light socket with a bulb and wire it up. Make sure it has power and make sure switch works. Turn the switch off, then wire your light.
Old 02-11-17, 10:44 AM
@ X ................ 10 A.C. V ?
You have a center hole canopy. You'll need a fixture bar that connects to that box.
Old 02-11-17, 10:53 AM
T
Thanks PJmax for the reply. I watched so many youtube videos and got nowhere. Yes, that is 250 that you circled so I will set it to that.
"The ground connects to the short bare ground wire in the box.
The smooth side is the hot/black side."
This part above you are referring to the wires coming out of the chandelier- correct? I attach the skinny copper wire to the stubby bare wire coming out of the ceiling.- I think it's been painted white-
I think I see what you mean about the ridges. I thought they were both the same but I can feel ridges on one.
Thanks very much for your help!
Old 02-11-17, 10:57 AM
T
I put in a new battery this morning XSleeper- thanks!
I will check the bar in the attic Pjmax. Thanks guys!
Old 02-11-17, 11:09 AM
XSleeper's Avatar
120V... can't read the fine print on my phone.
Old 02-11-17, 11:14 AM
The fixture bar attaches to the box and is used to attach the light to.
Old 02-11-17, 11:59 AM
ray2047's Avatar
No battery needed in an analog meter to read voltage. Battery is only for resistance. To test a meter's voltage function insert probes into a known good receptacle.
Old 02-11-17, 01:45 PM
T
It's me again. I looked at my lamp again and found the bar you are talking about Pjmax- also 2 screws included.
Thanks to your help with the meter, I now know what breaker to switch off. The only concerns I have now are the following:
The old fixture used those little flame shaped bulbs- six of them I think. The kind where the sockets are smaller. This fixture holds 5 standard size bulbs. Will this be a problem?
Also, this fixture probably weighs more than the old one. I looked at the bar in the attic that the box is attached to. It looks like prongs on either end were hammered into the 2 beams. I didn't see any screws. Should I replace this with a new bar? I can weigh the lamp and buy one sturdy enough. I can take pictures if that helps.
I would appreciate any help with this. I will probably work on this some more next weekend.
Thanks!
Old 02-11-17, 01:55 PM
The new fixture may use slightly more power but I don't see any issue there.
Those old bar boxes could take a good amount of weight. A rule of thumb is not to exceed 35 pounds of static weight.
If there is a place to put screws into the hanger bars.... do it.
Usually they were held to the joists with a nail or two. Sometimes even a staple or two.
